<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Improve spool ID search and allow direct printer&#x2F;AMS assignment from the spool view]]></title><description><![CDATA[<p dir="auto">Problem and motivation</p>
<p dir="auto">Larger print farms often have several visually identical filament spools. The sequential Bambuddy spool ID and its QR code are therefore the only unambiguous link to the physical spool.</p>
<p dir="auto">In the existing workflow, the spool ID was not visible in the assignment list and could not be searched exactly. Searching for “3”, for example, could also return spools 13 or 30. In addition, a spool opened through its QR code could not be assigned directly to a printer or AMS slot. The assignment had to be started from the printer instead.</p>
<p dir="auto">Useful improvements:</p>
<p dir="auto">Display the spool ID as #ID<br />
Support exact searches such as #3 while preserving the existing general search<br />
Assign a spool directly from its edit and QR-code view<br />
Select the printer, AMS or external slot, and spool colour in one dialog<br />
Require explicit confirmation instead of assigning immediately after a slot click<br />
Provide a responsive and more accessible dialog with translations<br />
Automatically follow Bambuddy’s configured light or dark theme</p>
<p dir="auto">This creates a shorter and less error-prone workflow from the physical spool’s QR code to the correct AMS slot, especially for users managing many identical spools.</p>
<p dir="auto">Test installer for v1.2.6b1 beta</p>
<p dir="auto">I can also provide a self-contained patch installer for the original Bambuddy v1.2.6b1 beta build (commit 14f4651) if the maintainers or other users would like to test the proposed workflow.</p>
<p dir="auto">The installer verifies the exact source version, applies the complete patch, rebuilds the frontend, creates a backup of the current installation, and automatically rolls back the changes if the build or service restart fails.</p>
<p dir="auto">It is intentionally version-specific and intended only for testing on the original v1.2.6b1 beta, not as a general installer for current or future Bambuddy releases.</p>
]]></description><link>https://forum.bambuddy.cool/topic/119/improve-spool-id-search-and-allow-direct-printer-ams-assignment-from-the-spool-view</link><generator>RSS for Node</generator><lastBuildDate>Tue, 15 Sep 2026 00:43:47 GMT</lastBuildDate><atom:link href="https://forum.bambuddy.cool/topic/119.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 27 Aug 2026 18:27:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Improve spool ID search and allow direct printer&#x2F;AMS assignment from the spool view on Fri, 28 Aug 2026 06:20:59 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I've done that. I also included the patch from the latest beta. That's how I'm already using it.<br />
<a href="https://github.com/maziggy/bambuddy/issues/2978" rel="nofollow ugc">https://github.com/maziggy/bambuddy/issues/2978</a></p>
]]></description><link>https://forum.bambuddy.cool/post/292</link><guid isPermaLink="true">https://forum.bambuddy.cool/post/292</guid><dc:creator><![CDATA[pd81]]></dc:creator><pubDate>Fri, 28 Aug 2026 06:20:59 GMT</pubDate></item><item><title><![CDATA[Reply to Improve spool ID search and allow direct printer&#x2F;AMS assignment from the spool view on Fri, 28 Aug 2026 05:29:56 GMT]]></title><description><![CDATA[<p dir="auto">This should go into a feature request on Github.</p>
]]></description><link>https://forum.bambuddy.cool/post/291</link><guid isPermaLink="true">https://forum.bambuddy.cool/post/291</guid><dc:creator><![CDATA[MartinNYHC]]></dc:creator><pubDate>Fri, 28 Aug 2026 05:29:56 GMT</pubDate></item></channel></rss>
