<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Troubleshooting: Common Issues and Solutions]]></title><description><![CDATA[<p dir="auto">A collection of frequently reported issues and their solutions.</p>
<h2>Printer Shows as Offline</h2>
<p dir="auto"><strong>Cause:</strong> Network connectivity or Developer Mode not enabled.</p>
<p dir="auto"><strong>Fix:</strong></p>
<ol>
<li>Verify Developer Mode is enabled on the printer</li>
<li>Confirm the printer and Bambuddy are on the same network/VLAN</li>
<li>Check the IP address in Settings &gt; Printers</li>
<li>Restart the printer if it was recently updated</li>
</ol>
<h2>Camera Not Showing Preview</h2>
<p dir="auto"><strong>Cause:</strong> Camera stream not accessible or blocked.</p>
<ol>
<li>Make sure the camera is enabled in your printer's settings</li>
<li>Check that port 6000 (RTSP) is not blocked by a firewall</li>
<li>For X1C/P1S: camera works over LAN only with Developer Mode</li>
<li>Try refreshing the browser or clearing cache</li>
</ol>
<h2>Print Won't Start from Queue/Archive</h2>
<p dir="auto"><strong>Cause:</strong> Filament mismatch, printer busy, or file transfer issue.</p>
<ol>
<li>Check that the printer has the required filaments loaded</li>
<li>Make sure the printer isn't already printing or in error state</li>
<li>Check the queue status — it might be in "Queue Only" mode</li>
<li>Verify the 3MF file isn't corrupted (try downloading and opening in slicer)</li>
</ol>
<h2>Large File Upload Fails</h2>
<p dir="auto"><strong>Cause:</strong> Timeout or proxy configuration.</p>
<ol>
<li>If using a reverse proxy, increase <code>client_max_body_size</code> and timeouts</li>
<li>For direct access, check available disk space</li>
<li>Try a wired connection instead of WiFi</li>
</ol>
<h2>AMS Mapping Shows Wrong Colors</h2>
<p dir="auto"><strong>Cause:</strong> AMS slot configuration out of sync.</p>
<ol>
<li>Go to the Printers page and click on the AMS slots to refresh</li>
<li>Try the RFID re-read button for affected slots</li>
<li>Ensure spools are properly assigned in the Spool Inventory</li>
</ol>
<h2>Docker on Windows: Network Issues</h2>
<p dir="auto"><strong>Cause:</strong> Docker Desktop doesn't support host networking.</p>
<ol>
<li>Enter your printer's IP address manually in Bambuddy settings</li>
<li>Don't rely on auto-discovery (SSDP) — it won't work through Docker Desktop's NAT</li>
</ol>
<p dir="auto">Still stuck? Create a new topic in the <strong>Help</strong> category with:</p>
<li>Your Bambuddy version</li>
<li>Printer model</li>
<li>A <a href="https://wiki.bambuddy.cool/features/system-info/?h=debug#enable-debug-logging" rel="nofollow ugc">Support Package</a></li>
]]></description><link>https://forum.bambuddy.cool/topic/19/troubleshooting-common-issues-and-solutions</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 15:42:50 GMT</lastBuildDate><atom:link href="https://forum.bambuddy.cool/topic/19.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 Apr 2026 13:07:15 GMT</pubDate><ttl>60</ttl></channel></rss>
