<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Won&#x27;t install]]></title><description><![CDATA[<p dir="auto">OS: Linux Mint 22.3,  updated to latest packages (installed 10 minutes ago).</p>
<p dir="auto">Intel NUC:</p>
<li>CPU i3-6100</li>
<li>8gb RAM</li>
<li>210GB of free hard drive space</li>
<p dir="auto">I'm trying to do a native install with this command:</p>
<p dir="auto">curl -fsSL <a href="https://raw.githubusercontent.com/maziggy/bambuddy/main/install/install.sh" rel="nofollow ugc">https://raw.githubusercontent.com/maziggy/bambuddy/main/install/install.sh</a> -o <a href="http://install.sh" rel="nofollow ugc">install.sh</a> &amp;&amp; chmod +x <a href="http://install.sh" rel="nofollow ugc">install.sh</a> &amp;&amp; ./install.sh</p>
<p dir="auto">I get this error:</p>
<p dir="auto">curl: (23) Failure writing output to destination</p>
<p dir="auto">So I tried the same command with sudo, and got this error:</p>
<p dir="auto">chmod: changing permissions of '<a href="http://install.sh" rel="nofollow ugc">install.sh</a>': Operation not permitted</p>
<p dir="auto">I'm at the very edge of my linux trouble-shooting abilities.</p>
]]></description><link>https://forum.bambuddy.cool/topic/45/won-t-install</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 16:13:57 GMT</lastBuildDate><atom:link href="https://forum.bambuddy.cool/topic/45.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 29 Apr 2026 23:29:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Won&#x27;t install on Thu, 30 Apr 2026 20:25:03 GMT]]></title><description><![CDATA[<p dir="auto">And i'm up and running!</p>
]]></description><link>https://forum.bambuddy.cool/post/75</link><guid isPermaLink="true">https://forum.bambuddy.cool/post/75</guid><dc:creator><![CDATA[jsimmonstx]]></dc:creator><pubDate>Thu, 30 Apr 2026 20:25:03 GMT</pubDate></item><item><title><![CDATA[Reply to Won&#x27;t install on Thu, 30 Apr 2026 19:59:17 GMT]]></title><description><![CDATA[<p dir="auto">i came back to say i fingered it out. i had to sudo chmod, and then i was able to run <a href="http://install.sh" rel="nofollow ugc">install.sh</a></p>
]]></description><link>https://forum.bambuddy.cool/post/74</link><guid isPermaLink="true">https://forum.bambuddy.cool/post/74</guid><dc:creator><![CDATA[jsimmonstx]]></dc:creator><pubDate>Thu, 30 Apr 2026 19:59:17 GMT</pubDate></item><item><title><![CDATA[Reply to Won&#x27;t install on Thu, 30 Apr 2026 19:50:28 GMT]]></title><description><![CDATA[<p dir="auto">That's a bit weird, can you run the commands one after the other?</p>
<p dir="auto">First <code>curl -fsSL https://raw.githubusercontent.com/maziggy/bambuddy/main/install/install.sh -o install.sh</code></p>
<p dir="auto">Then <code>chmod +x install.sh</code></p>
<p dir="auto">Then <code>sudo ./install.sh</code></p>
<p dir="auto">Report back here on the errors you face and I'll try to help you troubleshoot.</p>
]]></description><link>https://forum.bambuddy.cool/post/73</link><guid isPermaLink="true">https://forum.bambuddy.cool/post/73</guid><dc:creator><![CDATA[ash_t]]></dc:creator><pubDate>Thu, 30 Apr 2026 19:50:28 GMT</pubDate></item><item><title><![CDATA[Reply to Won&#x27;t install on Thu, 30 Apr 2026 10:51:38 GMT]]></title><description><![CDATA[<p dir="auto">I didn't see Mint in the list of compatible OS's, but since it's based on Ubuntu, I assumed it would be okay. Is that an incorrect assumption?</p>
<p dir="auto">BTW, the time limit on editing a post is arbitarrary and absurd. I don't see the point at all...</p>
]]></description><link>https://forum.bambuddy.cool/post/72</link><guid isPermaLink="true">https://forum.bambuddy.cool/post/72</guid><dc:creator><![CDATA[jsimmonstx]]></dc:creator><pubDate>Thu, 30 Apr 2026 10:51:38 GMT</pubDate></item></channel></rss>
