<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Prints start paused]]></title><description><![CDATA[<p dir="auto">Every print I start, gets paused because there's something on the buildplate. But there isn't. I checked the workflow setting "Plate Clear Confirmation". because I thought it has something to do with it. I even tried the slider both ways, in case it has (accidental) reverse logic. Never had it before I switched to Bambuddy. The printer itself isn't complaining about anything, it's Bambuddy. But I do have to resume the print otherwise it stays paused.<br />
What's going on?</p>
]]></description><link>https://forum.bambuddy.cool/topic/48/prints-start-paused</link><generator>RSS for Node</generator><lastBuildDate>Sat, 07 Nov 2026 13:46:26 GMT</lastBuildDate><atom:link href="https://forum.bambuddy.cool/topic/48.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 06 May 2026 22:45:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Prints start paused on Thu, 07 May 2026 05:42:16 GMT]]></title><description><![CDATA[<p dir="auto">My understanding is that if you have print plate confirmation checked, the print will not start till you set the plate as cleared on the printer page. Also, on the printer card, check if you have plate check enabled. It uses an image detection algo to check if there is something still on the build plate. I've found it to have too many false positives, so I just disabled it and am relying on plate clear confirmation. Check the screenshot to see the plate check toggle I am referring to.</p>
<p dir="auto"><img src="/assets/uploads/files/1778132512952-aef4adaa-bba1-4f5f-b2e1-81c9c8882c29-image.jpeg" alt="aef4adaa-bba1-4f5f-b2e1-81c9c8882c29-image.jpeg" class="img-markdown  img-fluid" width="674" height="178" /></p>
]]></description><link>https://forum.bambuddy.cool/post/82</link><guid isPermaLink="true">https://forum.bambuddy.cool/post/82</guid><dc:creator><![CDATA[ash_t]]></dc:creator><pubDate>Thu, 07 May 2026 05:42:16 GMT</pubDate></item></channel></rss>
