<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem Installing on Linux Machine]]></title><description><![CDATA[<p dir="auto">Hi There<br />
So i wanted to install Bambuddy on my machine and used the command provided.<br />
Yet i get the error that the Docker Deamon is not running, yet i checked and it should run as the dockerd command shows.</p>
<p dir="auto"><img src="https://i.imgur.com/913OxMN.png" alt="alt text" class="img-markdown  img-fluid" /></p>
<p dir="auto">Any ideas?!<br />
Thanks for the help!</p>
]]></description><link>https://forum.bambuddy.cool/topic/51/problem-installing-on-linux-machine</link><generator>RSS for Node</generator><lastBuildDate>Thu, 15 Oct 2026 17:38:29 GMT</lastBuildDate><atom:link href="https://forum.bambuddy.cool/topic/51.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 10 May 2026 17:59:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem Installing on Linux Machine on Mon, 11 May 2026 15:00:17 GMT]]></title><description><![CDATA[<p dir="auto">Still doesnt work.<br />
But I got it working via "manual" mode. Here it just worked.<br />
Pulled the image and fired up the container. <img src="https://forum.bambuddy.cool/assets/plugins/nodebb-plugin-emoji/emoji/apple/1f643.png?v=d3e0781e3e6" class="not-responsive emoji emoji-apple emoji--upside_down_face" style="height:1.4em;width:auto;vertical-align:middle" title="🙃" alt="🙃" />🤪<br />
Still thanks for your help and this great programm! <img src="https://forum.bambuddy.cool/assets/plugins/nodebb-plugin-emoji/emoji/apple/1f918.png?v=d3e0781e3e6" class="not-responsive emoji emoji-apple emoji--the_horns" style="height:1.4em;width:auto;vertical-align:middle" title="🤘" alt="🤘" /><img src="https://forum.bambuddy.cool/assets/plugins/nodebb-plugin-emoji/emoji/apple/1f601.png?v=d3e0781e3e6" class="not-responsive emoji emoji-apple emoji--grin" style="height:1.4em;width:auto;vertical-align:middle" title="😁" alt="😁" /></p>
]]></description><link>https://forum.bambuddy.cool/post/93</link><guid isPermaLink="true">https://forum.bambuddy.cool/post/93</guid><dc:creator><![CDATA[DofD10]]></dc:creator><pubDate>Mon, 11 May 2026 15:00:17 GMT</pubDate></item><item><title><![CDATA[Reply to Problem Installing on Linux Machine on Mon, 11 May 2026 14:56:13 GMT]]></title><description><![CDATA[<p dir="auto">Just do</p>
<p dir="auto">sudo systemctl enable --now docker.service &amp;&amp; sudo systemctl status docker.service</p>
]]></description><link>https://forum.bambuddy.cool/post/92</link><guid isPermaLink="true">https://forum.bambuddy.cool/post/92</guid><dc:creator><![CDATA[MartinNYHC]]></dc:creator><pubDate>Mon, 11 May 2026 14:56:13 GMT</pubDate></item><item><title><![CDATA[Reply to Problem Installing on Linux Machine on Mon, 11 May 2026 14:53:42 GMT]]></title><description><![CDATA[<p dir="auto">Then I dont understand, are there different versions of docker?<br />
I used the install guide at <a href="https://docs.docker.com/engine/install/ubuntu/" rel="nofollow ugc">https://docs.docker.com/engine/install/ubuntu/</a> and checked that it is running.<br />
Do i miss something here? If i do it the manual way (pre built image) it just works...<br />
Sorry for this basic question as this is the first time i am running into problems with docker.</p>
]]></description><link>https://forum.bambuddy.cool/post/91</link><guid isPermaLink="true">https://forum.bambuddy.cool/post/91</guid><dc:creator><![CDATA[DofD10]]></dc:creator><pubDate>Mon, 11 May 2026 14:53:42 GMT</pubDate></item><item><title><![CDATA[Reply to Problem Installing on Linux Machine on Mon, 11 May 2026 05:59:38 GMT]]></title><description><![CDATA[<p dir="auto">You are checking the wrong service.</p>
<p dir="auto">systemctl status docker.s<br />
docker.service  docker.socket</p>
<p dir="auto">doocker.service is the right one.</p>
]]></description><link>https://forum.bambuddy.cool/post/90</link><guid isPermaLink="true">https://forum.bambuddy.cool/post/90</guid><dc:creator><![CDATA[MartinNYHC]]></dc:creator><pubDate>Mon, 11 May 2026 05:59:38 GMT</pubDate></item><item><title><![CDATA[Reply to Problem Installing on Linux Machine on Sun, 10 May 2026 19:43:36 GMT]]></title><description><![CDATA[<p dir="auto">Still showing error after restarting<br />
<img src="https://i.imgur.com/Ku9CPhE.png" alt="alt text" class="img-markdown  img-fluid" /></p>
]]></description><link>https://forum.bambuddy.cool/post/89</link><guid isPermaLink="true">https://forum.bambuddy.cool/post/89</guid><dc:creator><![CDATA[DofD10]]></dc:creator><pubDate>Sun, 10 May 2026 19:43:36 GMT</pubDate></item><item><title><![CDATA[Reply to Problem Installing on Linux Machine on Sun, 10 May 2026 18:05:05 GMT]]></title><description><![CDATA[<p dir="auto">Mhhh...never saw that before. Restart Docker and check your logs for errors.</p>
]]></description><link>https://forum.bambuddy.cool/post/88</link><guid isPermaLink="true">https://forum.bambuddy.cool/post/88</guid><dc:creator><![CDATA[MartinNYHC]]></dc:creator><pubDate>Sun, 10 May 2026 18:05:05 GMT</pubDate></item></channel></rss>
