<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Weird Network Issues?]]></title><description><![CDATA[<p dir="auto">Hi There,</p>
<p dir="auto">Pretty new to Bambuddy (but not new to Bambu/3D printing/docker), having a couple of strange issues - hoping they can be easily solved.</p>
<p dir="auto">BB v0.2.4 (with HASS &amp; Fail detection working)<br />
Spoolman Version 0.23.1 (usage tracking works)<br />
X1C (Lan only mode)<br />
Bambu Studio 2.6.1.53</p>
<p dir="auto">Trying to send a print from BS via - slice - print plate I get this error.</p>
<p dir="auto"><img src="/assets/uploads/files/1778715892702-f383501d-faf2-4dfc-a43a-63bd369282a1-image.jpeg" alt="f383501d-faf2-4dfc-a43a-63bd369282a1-image.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Searching for it - doesn't really give me much information - I have printed directly since this has been set up, but lately i've had to export the sliced gcode and upload into BB and print from there - which does work without issue.</p>
<p dir="auto">The other is that if I open the camera view of the printer, it will freeze after a few seconds, pressing the refresh button does re-connect and show another few seconds, same behaviour as when it times out and re-connects on its own.</p>
<p dir="auto">Not sure if I'm using things wrongly etc or ? no errors sticking out in the docker logs.</p>
<p dir="auto">Cheers Steve.</p>
]]></description><link>https://forum.bambuddy.cool/topic/58/weird-network-issues</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 15:38:32 GMT</lastBuildDate><atom:link href="https://forum.bambuddy.cool/topic/58.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 14 May 2026 00:00:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Weird Network Issues? on Thu, 14 May 2026 05:46:40 GMT]]></title><description><![CDATA[<p dir="auto">Please open an issue on Github and attach a support-package.</p>
<p dir="auto"><a href="https://wiki.bambuddy.cool/features/system-info/?h=debug#enable-debug-logging" rel="nofollow ugc">https://wiki.bambuddy.cool/features/system-info/?h=debug#enable-debug-logging</a></p>
]]></description><link>https://forum.bambuddy.cool/post/107</link><guid isPermaLink="true">https://forum.bambuddy.cool/post/107</guid><dc:creator><![CDATA[MartinNYHC]]></dc:creator><pubDate>Thu, 14 May 2026 05:46:40 GMT</pubDate></item><item><title><![CDATA[Reply to Weird Network Issues? on Thu, 14 May 2026 04:59:10 GMT]]></title><description><![CDATA[<p dir="auto">Update - The camera stream doesn't hang, if there isn't a print going on (watching the stream, turning the light on &amp; off etc seems fine)</p>
<p dir="auto">edit -</p>
<p dir="auto">further testing and logwatching - the hangs are happening when the fault detection fires -</p>
<pre><code>bambuddy  | 2026-05-14 14:53:54,969 INFO [backend.app.api.routes.camera] [a6fa2778] Using RTSP protocol for X1C
bambuddy  | 2026-05-14 14:53:54,969 INFO [backend.app.api.routes.camera] [a6fa2778] Camera viewer attached to printer-1 (subscribers=1)
bambuddy  | 2026-05-14 14:53:58,010 WARNING [backend.app.api.routes.camera] [34034de4] RTSP read timeout for 10.0.20.9 (stream_id=1-fanout)
bambuddy  | 2026-05-14 14:53:58,542 INFO [backend.app.services.camera] [-] Capturing camera frame bytes from 10.0.20.9 using RTSP (model: X1C)
bambuddy  | 2026-05-14 14:54:00,011 WARNING [backend.app.api.routes.camera] [34034de4] ffmpeg didn't terminate gracefully, killing (stream_id=1-fanout)
bambuddy  | 2026-05-14 14:54:00,022 INFO [backend.app.api.routes.camera] [34034de4] RTSP reconnecting (1/30) for 10.0.20.9 (stream_id=1-fanout)
bambuddy  | 2026-05-14 14:54:00,425 INFO [backend.app.services.camera] [-] Successfully captured camera frame bytes: 64224 bytes
bambuddy  | 2026-05-14 14:54:12,203 INFO [backend.app.services.camera] [-] Capturing camera frame bytes from 10.0.20.9 using RTSP (model: X1C)
bambuddy  | 2026-05-14 14:54:14,097 INFO [backend.app.services.camera] [-] Successfully captured camera frame bytes: 67890 bytes
bambuddy  | 2026-05-14 14:54:27,217 INFO [backend.app.services.camera] [-] Capturing camera frame bytes from 10.0.20.9 using RTSP (model: X1C)
bambuddy  | 2026-05-14 14:54:29,155 INFO [backend.app.services.camera] [-] Successfully captured camera frame bytes: 72468 bytes
bambuddy  | 2026-05-14 14:54:40,402 INFO [backend.app.api.routes.camera] [a6fa2778] Camera viewer detached from printer-1 (subscribers=0)
bambuddy  | 2026-05-14 14:54:40,419 INFO [backend.app.api.routes.camera] [34034de4] Camera stream cancelled (stream_id=1-fanout)
bambuddy  | 2026-05-14 14:54:40,507 INFO [backend.app.api.routes.camera] [658b9606] Using RTSP protocol for X1C
bambuddy  | 2026-05-14 14:54:40,507 INFO [backend.app.api.routes.camera] [658b9606] Camera viewer attached to printer-1 (subscribers=1)
bambuddy  | 2026-05-14 14:54:40,508 INFO [backend.app.api.routes.camera] [658b9606] Starting RTSP camera stream for 10.0.20.9 (stream_id=1-fanout, model=X1C, fps=15)
bambuddy  | 2026-05-14 14:54:42,284 INFO [backend.app.services.camera] [-] Capturing camera frame bytes from 10.0.20.9 using RTSP (model: X1C)
bambuddy  | 2026-05-14 14:54:42,420 WARNING [backend.app.api.routes.camera] [34034de4] ffmpeg didn't terminate gracefully, killing (stream_id=1-fanout)
bambuddy  | 2026-05-14 14:54:44,210 INFO [backend.app.services.camera] [-] Successfully captured camera frame bytes: 70629 bytes
bambuddy  | 2026-05-14 14:54:56,006 INFO [backend.app.services.camera] [-] Capturing camera frame bytes from 10.0.20.9 using RTSP (model: X1C)
bambuddy  | 2026-05-14 14:54:57,903 INFO [backend.app.services.camera] [-] Successfully captured camera frame bytes: 71444 bytes
bambuddy  | 2026-05-14 14:55:09,694 INFO [backend.app.services.camera] [-] Capturing camera frame bytes from 10.0.20.9 using RTSP (model: X1C)
bambuddy  | 2026-05-14 14:55:09,714 INFO [backend.app.api.routes.camera] [658b9606] Camera viewer detached from printer-1 (subscribers=0)
bambuddy  | 2026-05-14 14:55:09,718 INFO [backend.app.api.routes.camera] [109457ee] Using RTSP protocol for X1C
bambuddy  | 2026-05-14 14:55:09,718 INFO [backend.app.api.routes.camera] [109457ee] Camera viewer attached to printer-1 (subscribers=1)
bambuddy  | 2026-05-14 14:55:11,656 INFO [backend.app.services.camera] [-] Successfully captured camera frame bytes: 63267 bytes
bambuddy  | 2026-05-14 14:55:19,817 INFO [backend.app.api.routes.camera] [109457ee] Camera viewer detached from printer-1 (subscribers=0)
bambuddy  | 2026-05-14 14:55:19,817 INFO [backend.app.api.routes.camera] [658b9606] Camera stream cancelled (stream_id=1-fanout)
bambuddy  | 2026-05-14 14:55:19,917 INFO [backend.app.api.routes.camera] [68fb9162] Using RTSP protocol for X1C
bambuddy  | 2026-05-14 14:55:19,918 INFO [backend.app.api.routes.camera] [68fb9162] Camera viewer attached to printer-1 (subscribers=1)
bambuddy  | 2026-05-14 14:55:19,918 INFO [backend.app.api.routes.camera] [68fb9162] Starting RTSP camera stream for 10.0.20.9 (stream_id=1-fanout, model=X1C, fps=15)
bambuddy  | 2026-05-14 14:55:20,300 INFO [backend.app.api.routes.camera] [397bf934] Shut down camera fan-out broadcaster for printer 1
bambuddy  | 2026-05-14 14:55:20,300 INFO [backend.app.api.routes.camera] [397bf934] Stopped 0 camera stream(s) for printer 1
bambuddy  | INFO:     172.31.0.8:34472 - "POST /api/v1/printers/1/camera/stop HTTP/1.1" 200 OK
bambuddy  | 2026-05-14 14:55:23,439 INFO [backend.app.services.camera] [-] Capturing camera frame bytes from 10.0.20.9 using RTSP (model: X1C)
bambuddy  | 2026-05-14 14:55:25,350 INFO [backend.app.services.camera] [-] Successfully captured camera frame bytes: 37452 bytes
bambuddy  | 2026-05-14 14:55:29,170 INFO [backend.app.api.routes.camera] [68fb9162] Camera viewer detached from printer-1 (subscribers=0)
bambuddy  | 2026-05-14 14:55:29,178 INFO [backend.app.api.routes.camera] [03c4106c] Using RTSP protocol for X1C
bambuddy  | 2026-05-14 14:55:29,179 INFO [backend.app.api.routes.camera] [03c4106c] Camera viewer attached to printer-1 (subscribers=1)
bambuddy  | 2026-05-14 14:55:36,252 INFO [backend.app.api.routes.camera] [773b5487] Using RTSP protocol for X1C
bambuddy  | 2026-05-14 14:55:36,252 INFO [backend.app.api.routes.camera] [773b5487] Camera viewer attached to printer-1 (subscribers=2)
bambuddy  | 2026-05-14 14:55:36,260 INFO [backend.app.api.routes.camera] [773b5487] Camera viewer detached from printer-1 (subscribers=1)
bambuddy  | INFO:     172.31.0.8:50416 - "PUT /api/v1/settings/ HTTP/1.1" 200 OK
bambuddy  | 2026-05-14 14:55:43,296 INFO [backend.app.api.routes.camera] [773b5487] Camera viewer detached from printer-1 (subscribers=0)
bambuddy  | 2026-05-14 14:55:43,306 INFO [backend.app.api.routes.camera] [d40345cf] Using RTSP protocol for X1C
bambuddy  | 2026-05-14 14:55:43,306 INFO [backend.app.api.routes.camera] [d40345cf] Camera viewer attached to printer-1 (subscribers=1)
bambuddy  | 2026-05-14 14:55:47,684 INFO [backend.app.api.routes.camera] [d40345cf] Camera viewer detached from printer-1 (subscribers=0)
bambuddy  | 2026-05-14 14:55:47,693 INFO [backend.app.api.routes.camera] [68fb9162] Camera stream cancelled (stream_id=1-fanout)
bambuddy  | 2026-05-14 14:55:47,789 INFO [backend.app.api.routes.camera] [c5bbe1b1] Using RTSP protocol for X1C
bambuddy  | 2026-05-14 14:55:47,789 INFO [backend.app.api.routes.camera] [c5bbe1b1] Camera viewer attached to printer-1 (subscribers=1)
bambuddy  | 2026-05-14 14:55:47,790 INFO [backend.app.api.routes.camera] [c5bbe1b1] Starting RTSP camera stream for 10.0.20.9 (stream_id=1-fanout, model=X1C, fps=15)
bambuddy  | 2026-05-14 14:55:49,695 WARNING [backend.app.api.routes.camera] [68fb9162] ffmpeg didn't terminate gracefully, killing (stream_id=1-fanout)
</code></pre>
<p dir="auto">Turning off AI failure detection - the camera stream functions normally.</p>
]]></description><link>https://forum.bambuddy.cool/post/106</link><guid isPermaLink="true">https://forum.bambuddy.cool/post/106</guid><dc:creator><![CDATA[SL666]]></dc:creator><pubDate>Thu, 14 May 2026 04:59:10 GMT</pubDate></item></channel></rss>
