<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Bambuddy will not list archives]]></title><description><![CDATA[<p dir="auto">Basically I have bambuddy setup, and when I click on "archives" it shows nothing and the docker instance log prints out like 10 pages of python errors, and nothing shows up in the actual bambuddy logs.. because I assume the python error is preempting it.</p>
<p dir="auto">There's no FTP issue, the archives are getting created and transferred to the directory.  The error occurs when I try to view Archives in the web-app, and it appears to be something wrong with the API call not getting what it expects.  I don't know enough about the code to understand the error.</p>
<p dir="auto">I am using version 2.4.6 on maziggy/bambuddy docker instance on a raspberry pi 5 with docker setup.</p>
<p dir="auto">I'm hoping this is something simple/weird with my setup and not an actual bug.</p>
<p dir="auto">Here is the error in the docker logs:</p>
<pre><code>INFO:     172.16.6.29:49362 - "POST /api/v1/cloud/filament-info HTTP/1.1" 200 OK
ERROR:    Exception in ASGI application
  + Exception Group Traceback (most recent call last):
  |   File "/usr/local/lib/python3.13/site-packages/starlette/_utils.py", line 81, in collapse_excgroups
  |     yield
  |   File "/usr/local/lib/python3.13/site-packages/starlette/middleware/base.py", line 192, in __call__
  |     async with anyio.create_task_group() as task_group:
  |   File "/usr/local/lib/python3.13/site-packages/anyio/_backends/_asyncio.py", line 799, in __aexit__
  |     raise BaseExceptionGroup(
  |         "unhandled errors in a TaskGroup", self._exceptions
  |     ) from None
  | ExceptionGroup: unhandled errors in a TaskGroup (1 sub-exception)
  +-+---------------- 1 ----------------
    |   File "/usr/local/lib/python3.13/site-packages/uvicorn/protocols/http/httptools_impl.py", line 421, in run_asgi
    |     result = await app(  # type: ignore[func-returns-value]
    |         self.scope, self.receive, self.send
    |   File "/usr/local/lib/python3.13/site-packages/uvicorn/middleware/proxy_headers.py", line 62, in __call__
    |     return await self.app(scope, receive, send)
    |   File "/usr/local/lib/python3.13/site-packages/fastapi/applications.py", line 1159, in __call__
    |     await super().__call__(scope, receive, send)
    |   File "/usr/local/lib/python3.13/site-packages/starlette/applications.py", line 90, in __call__
    |     await self.middleware_stack(scope, receive, send)
    |   File "/usr/local/lib/python3.13/site-packages/starlette/middleware/errors.py", line 186, in __call__
    |     raise exc
    |   File "/usr/local/lib/python3.13/site-packages/starlette/middleware/errors.py", line 164, in __call__
    |     await self.app(scope, receive, _send)
    |   File "/usr/local/lib/python3.13/site-packages/starlette/middleware/base.py", line 191, in __call__
    |     with recv_stream, send_stream, collapse_excgroups():
    |   File "/usr/local/lib/python3.13/contextlib.py", line 162, in __exit__
    |     self.gen.throw(value)
    |   File "/usr/local/lib/python3.13/site-packages/starlette/_utils.py", line 87, in collapse_excgroups
    |     raise exc
    |   File "/usr/local/lib/python3.13/site-packages/starlette/middleware/base.py", line 193, in __call__
    |     response = await self.dispatch_func(request, call_next)
    |   File "/app/backend/app/main.py", line 6031, in trace_id_middleware
    |     response = await call_next(request)
    |   File "/usr/local/lib/python3.13/site-packages/starlette/middleware/base.py", line 168, in call_next
    |     raise app_exc from app_exc.__cause__ or app_exc.__context__
    |   File "/usr/local/lib/python3.13/site-packages/starlette/middleware/base.py", line 144, in coro
    |     await self.app(scope, receive_or_disconnect, send_no_error)
    |     raise exc
    |   File "/app/backend/app/main.py", line 5992, in auth_middleware
    |     return await call_next(request)
    |     raise exc
    |   File "/app/backend/app/main.py", line 5800, in security_headers_middleware
    |   File "/usr/local/lib/python3.13/site-packages/starlette/middleware/exceptions.py", line 63, in __call__
    |     await wrap_app_handling_exceptions(self.app, conn)(scope, receive, send)
    |   File "/usr/local/lib/python3.13/site-packages/starlette/_exception_handler.py", line 53, in wrapped_app
    |     raise exc
    |   File "/usr/local/lib/python3.13/site-packages/starlette/_exception_handler.py", line 42, in wrapped_app
    |     await app(scope, receive, sender)
    |   File "/usr/local/lib/python3.13/site-packages/fastapi/middleware/asyncexitstack.py", line 18, in __call__
    |   File "/usr/local/lib/python3.13/site-packages/starlette/routing.py", line 660, in __call__
    |   File "/usr/local/lib/python3.13/site-packages/starlette/routing.py", line 680, in app
    |     await route.handle(scope, receive, send)
    |   File "/usr/local/lib/python3.13/site-packages/starlette/routing.py", line 276, in handle
    |   File "/usr/local/lib/python3.13/site-packages/fastapi/routing.py", line 134, in app
    |     await wrap_app_handling_exceptions(app, request)(scope, receive, send)
    |     raise exc
    |   File "/usr/local/lib/python3.13/site-packages/fastapi/routing.py", line 120, in app
    |     response = await f(request)
    |   File "/usr/local/lib/python3.13/site-packages/fastapi/routing.py", line 695, in app
    |     content = await serialize_response(
    |     ...&lt;11 lines&gt;...
    |   File "/usr/local/lib/python3.13/site-packages/fastapi/routing.py", line 300, in serialize_response
    |     raise ResponseValidationError(
    |     ...&lt;3 lines&gt;...
    | fastapi.exceptions.ResponseValidationError: 3 validation errors:
    |   {'type': 'datetime_type', 'loc': ('response', 0, 'created_at'), 'msg': 'Input should be a valid datetime', 'input': None}
    |   {'type': 'datetime_type', 'loc': ('response', 1, 'created_at'), 'msg': 'Input should be a valid datetime', 'input': None}
    |   {'type': 'datetime_type', 'loc': ('response', 2, 'created_at'), 'msg': 'Input should be a valid datetime', 'input': None}
    |   File "/app/backend/app/api/routes/archives.py", line 309, in list_archives
    |     GET /api/v1/archives/
The above exception was the direct cause of the following exception:
    raise exc
    raise exc
    raise exc
    raise exc
    raise exc
    raise exc
  |     yield
  |     ) from None
    |     raise exc
    |     raise exc
    |     raise exc
    |     raise exc
    |     raise exc
    |     raise exc
    raise exc
    raise exc
    raise exc
    raise exc
    raise exc
    raise exc
</code></pre>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.bambuddy.cool/topic/77/bambuddy-will-not-list-archives</link><generator>RSS for Node</generator><lastBuildDate>Wed, 24 Jun 2026 05:40:20 GMT</lastBuildDate><atom:link href="https://forum.bambuddy.cool/topic/77.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 12 Jun 2026 22:27:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Bambuddy will not list archives on Sun, 14 Jun 2026 06:18:47 GMT]]></title><description><![CDATA[<p dir="auto">All issue related details must go to the issue and not here in the forum!</p>
]]></description><link>https://forum.bambuddy.cool/post/182</link><guid isPermaLink="true">https://forum.bambuddy.cool/post/182</guid><dc:creator><![CDATA[MartinNYHC]]></dc:creator><pubDate>Sun, 14 Jun 2026 06:18:47 GMT</pubDate></item><item><title><![CDATA[Reply to Bambuddy will not list archives on Sat, 13 Jun 2026 22:44:16 GMT]]></title><description><![CDATA[<p dir="auto">Okay, I didn't entirely figure it out, but it <em>definitely</em> was a database error.  I did a backup and then wiped all the files/dbs/etc and restarted the docker so it was "new" again.  Painstakingly re-added every setting one by one and recopied the new cert over to my slicer and set up the virtual printer again to set it to immediately archive.  I sent the same print, and now it shows up in the archives.</p>
<p dir="auto">I will say, there is definitely a bug here, something to do with using a postgres database, saving the backup and then restoring to Sqlite definitely caused this, and I have a backup that if you restore it to a docker of bambuddy with sqlite it will break the list archives.</p>
<p dir="auto">For the record my install/docker settings have not changed since I moved to a standalone instance, so nothing about it was a broken install.  It's definitely some kind of garbage database transfer issue.</p>
]]></description><link>https://forum.bambuddy.cool/post/180</link><guid isPermaLink="true">https://forum.bambuddy.cool/post/180</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sat, 13 Jun 2026 22:44:16 GMT</pubDate></item><item><title><![CDATA[Reply to Bambuddy will not list archives on Sat, 13 Jun 2026 22:25:47 GMT]]></title><description><![CDATA[<p dir="auto">Could you please recheck the issue?  I've reinstalled again wiping the entire file structure and reloading the backup and it continues to not list archives and give the same python error.  I think it might be something messed up in the database, but I don't know enough about your code to know what is causing the error.</p>
<p dir="auto">If I provide the backup, can you try it yourself and see if you get the same error?</p>
]]></description><link>https://forum.bambuddy.cool/post/179</link><guid isPermaLink="true">https://forum.bambuddy.cool/post/179</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sat, 13 Jun 2026 22:25:47 GMT</pubDate></item><item><title><![CDATA[Reply to Bambuddy will not list archives on Sat, 13 Jun 2026 12:24:19 GMT]]></title><description><![CDATA[<p dir="auto">Done.  <a href="https://github.com/maziggy/bambuddy/issues/1732" rel="nofollow ugc">https://github.com/maziggy/bambuddy/issues/1732</a></p>
<p dir="auto">Hopefully it's something simple.</p>
]]></description><link>https://forum.bambuddy.cool/post/176</link><guid isPermaLink="true">https://forum.bambuddy.cool/post/176</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sat, 13 Jun 2026 12:24:19 GMT</pubDate></item><item><title><![CDATA[Reply to Bambuddy will not list archives on Sat, 13 Jun 2026 08:09:42 GMT]]></title><description><![CDATA[<p dir="auto">Please open an issue.</p>
]]></description><link>https://forum.bambuddy.cool/post/175</link><guid isPermaLink="true">https://forum.bambuddy.cool/post/175</guid><dc:creator><![CDATA[MartinNYHC]]></dc:creator><pubDate>Sat, 13 Jun 2026 08:09:42 GMT</pubDate></item></channel></rss>
