<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Installed package name on Linux?]]></title><description><![CDATA[<p dir="auto">Hey everyone.</p>
<p dir="auto">So I have Bambuddy installed on my Fedora (44) server and, after some use, I've decided it's not for me.</p>
<p dir="auto">The issue comes in with trying to uninstall it.  Nothing I have tried has worked and I can't even find anything similarly named on the package list.  Is it installed under a different name?</p>
<p dir="auto">Running</p>
<pre><code>sudo dnf remove bambuddy
</code></pre>
<p dir="auto">and anything similar just throws a package not found error.  But I can still stop/start/access the Bambuddy portal, so I know it's there somewhere.</p>
<p dir="auto">I had installed it using the quick install method, not docker, if that helps.</p>
<p dir="auto">Any help here is appreciated.</p>
]]></description><link>https://forum.bambuddy.cool/topic/97/installed-package-name-on-linux</link><generator>RSS for Node</generator><lastBuildDate>Sat, 17 Oct 2026 20:34:38 GMT</lastBuildDate><atom:link href="https://forum.bambuddy.cool/topic/97.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 10 Aug 2026 00:52:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Installed package name on Linux? on Mon, 10 Aug 2026 23:42:50 GMT]]></title><description><![CDATA[<p dir="auto">Will do.  I guess I didn't see anything in the documentation mentioning that it's standalone and doesn't register with the system.</p>
<p dir="auto">Thank you.</p>
]]></description><link>https://forum.bambuddy.cool/post/264</link><guid isPermaLink="true">https://forum.bambuddy.cool/post/264</guid><dc:creator><![CDATA[werewolfspider]]></dc:creator><pubDate>Mon, 10 Aug 2026 23:42:50 GMT</pubDate></item><item><title><![CDATA[Reply to Installed package name on Linux? on Mon, 10 Aug 2026 05:39:00 GMT]]></title><description><![CDATA[<p dir="auto">Stop it and delete the install folder.</p>
]]></description><link>https://forum.bambuddy.cool/post/263</link><guid isPermaLink="true">https://forum.bambuddy.cool/post/263</guid><dc:creator><![CDATA[MartinNYHC]]></dc:creator><pubDate>Mon, 10 Aug 2026 05:39:00 GMT</pubDate></item></channel></rss>
