  4. Admin Panel : refused to connect
12 Posts 2 Posters 544 Views 2 Watching
  • R
    R
    rillm
    Reinstalled Raspbian OS 64 bit Lite
    Reinstalled Babmbuddy (native Linux). Noted these warnings:
    WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'RemoteDisconnected('Remote end closed connection without response')': /simple/aiohttp/
    WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'RemoteDisconnected('Remote end closed connection without response')': /simple/ldap3/ldap3-2.9.1-py3-none-any.whl
    WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'RemoteDisconnected('Remote end closed connection without response')': /simple/markdown-it-py/markdown_it_py-4.2.0-py3-none-any.whl
    Created admin user and password with first login.
    Still cannot access Admin Panel : refused to connect.
    h e l p
      'sudo bambuddy-appliance set-admin-password'
      Appliance? That has nothing to do with a Bambuddy installation.
        Why dont you use the install command from the docs?
        • R
          R
          rillm
          I used this command from the docs (https://wiki.bambuddy.cool/getting-started/#__tabbed_1_4)
          curl -fsSL https://raw.githubusercontent.com/maziggy/bambuddy/main/install/install.sh -o install.sh && chmod +x install.sh && ./install.sh
            That's correct. So it should be accessible via port 8000 (and NOT 8001).
            • R
              R
              rillm
              Acccording to the Bambuddy Documentation at: https://wiki.bambuddy.cool/appliance/admin-panel/?h=admin
              • R
                R
                rillm
                Ok. I think I found the reason for my confusion:
                So, now my question is this:
                Can I add the Admin Panel to my self-install on my Pi-5 so I can access those same features as the Appliance?
                (Dashboard, Network, Updates, Diagnostics, Tailscale, etc)
                Thanks!
                P.S. I'll keep digging as well and if I find the answer will post it here.
                • R
                  R
                  rillm
                  wrote on last edited by rillm
                  #10
                  Specifically, I'm most interested in :
                  I can't find this anywhere in the standard Bambuddy web pages at :8000
                    • R
                      R
                      rillm
                      OK, so that's not an open-source option. Proprietary interface only available through purchase of the the Official Bambuddy Appliance.
                      Disappointingly expected.
                      Thanks
