  4. Error when sending to Virtual Printer
2 Posts 2 Posters 186 Views 2 Watching
  • O
    O
    ollie360
    I'm running Bambuddy on Docker. I was able to setup and add the virtual printer to my slicer but when I try to send a print to the virtual printer, I get an error.
    When I run the setup check it shows this:
    File-upload service (port 990)
    Nothing is listening on port 990 of the bind IP, so the slicer cannot upload files. A port conflict on this interface is the usual cause.
    Using netstat -ntlp, it shows nothing using port 990 when the container is stopped.
    The start up logs seem to show that the FTP service was started and showed no errors.
    bambuddy  | 2026-08-07 10:23:15,200 INFO [backend.app.services.virtual_printer.manager] [-] [VP Test] Starting server-mode services on 10.0.0.12
    bambuddy  | 2026-08-07 10:23:15,200 INFO [backend.app.services.virtual_printer.certificate] [-] Deleted printer certificate (CA preserved)
    bambuddy  | 2026-08-07 10:23:15,200 INFO [backend.app.services.virtual_printer.certificate] [-] Generating certificates for virtual printer (serial: 03900A391800002)...
    bambuddy  | 2026-08-07 10:23:15,254 INFO [backend.app.services.virtual_printer.certificate] [-] Using existing CA certificate (expires in 7147 days)
    bambuddy  | 2026-08-07 10:23:15,302 WARNING [backend.app.services.bambu_mqtt] [-] [03919C440802216] MQTT disconnected: rc=Unspecified error, flags=DisconnectFlags(is_disconnect_packet_from_server=False)
    bambuddy  | 2026-08-07 10:23:15,302 WARNING [backend.app.services.bambu_mqtt] [-] [03919C440802216] Disconnected shortly after request topic subscription. Disabling request topic for this printer.
    bambuddy  | 2026-08-07 10:23:15,384 INFO [backend.app.services.virtual_printer.certificate] [-] Generating printer certificate with CN=03900A391800002, local IP: 10.0.0.12
    bambuddy  | 2026-08-07 10:23:15,389 INFO [backend.app.services.virtual_printer.certificate] [-] Generated certificate chain at /app/data/virtual_printer/certs/2
    bambuddy  | 2026-08-07 10:23:15,389 INFO [backend.app.services.virtual_printer.certificate] [-]   CA: CN=Virtual Printer CA
    bambuddy  | 2026-08-07 10:23:15,389 INFO [backend.app.services.virtual_printer.certificate] [-]   Printer: CN=03900A391800002
    bambuddy  | 2026-08-07 10:23:15,389 INFO [backend.app.services.virtual_printer.mqtt_bridge] [-] [Test] MQTT bridge IP encoding armed: target=10.0.20.127 vp=10.0.0.12 (bind_address)
    bambuddy  | 2026-08-07 10:23:15,389 INFO [backend.app.services.virtual_printer.mqtt_bridge] [-] [Test] MQTT bridge bound to printer 1 (serial=03919X420802216)
    bambuddy  | 2026-08-07 10:23:15,390 INFO [backend.app.services.virtual_printer.ftp_server] [-] [Test] Starting virtual printer implicit FTPS on 10.0.0.12:990
    bambuddy  | 2026-08-07 10:23:15,391 INFO [backend.app.services.virtual_printer.ftp_server] [-] FTP SSL context created with standard settings
    bambuddy  | 2026-08-07 10:23:15,391 INFO [backend.app.services.virtual_printer.mqtt_server] [-] Starting simple MQTT server on port 8883
    bambuddy  | 2026-08-07 10:23:15,412 INFO [backend.app.services.virtual_printer.mqtt_server] [-] MQTT SSL cert info: subject=CN=03900A391800002
    bambuddy  | issuer=CN=Virtual Printer CA
    bambuddy  | 2026-08-07 10:23:15,412 INFO [backend.app.services.virtual_printer.mqtt_server] [-] MQTT SSL context: TLS 1.2+, cert=/app/data/virtual_printer/certs/2/virtual_printer.crt
    bambuddy  | 2026-08-07 10:23:15,412 INFO [backend.app.services.virtual_printer.tcp_proxy] [-] Starting Camera-6000 TCP proxy: 10.0.0.12:6000 → 10.0.20.127:6000
    bambuddy  | 2026-08-07 10:23:15,413 INFO [backend.app.services.virtual_printer.bind_server] [-] Starting bind server on ports [3000, 3002] (serial=03900A391800002, model=N2S, tls=True)
    bambuddy  | 2026-08-07 10:23:15,413 INFO [backend.app.services.virtual_printer.ssdp_server] [-] Starting virtual printer SSDP server: Test (03900A391800002)
    bambuddy  | 2026-08-07 10:23:15,414 INFO [backend.app.services.virtual_printer.ssdp_server] [-] SSDP server listening on port 2021, advertising IP: 10.0.0.12
    bambuddy  | 2026-08-07 10:23:15,414 INFO [backend.app.services.virtual_printer.ssdp_server] [-] Virtual printer: Test (03900A391800002) model=N2S
    bambuddy  | 2026-08-07 10:23:15,414 INFO [backend.app.services.virtual_printer.ssdp_server] [-] SSDP server also listening on 0.0.0.0:2021
    bambuddy  | 2026-08-07 10:23:15,414 INFO [backend.app.services.virtual_printer.ssdp_server] [-] Sent initial SSDP NOTIFY announcement
    bambuddy  | 2026-08-07 10:23:15,419 INFO [backend.app.main] [-] [#1752] Printer 1 connected→disconnected edge; scheduling offline notification in 60s
    bambuddy  | 2026-08-07 10:23:15,420 INFO [backend.app.services.virtual_printer.ftp_server] [-] Implicit FTPS server started on port 990
    bambuddy  | 2026-08-07 10:23:15,420 INFO [backend.app.services.virtual_printer.ftp_server] [-] FTP passive data port range: 50010-50019
    bambuddy  | 2026-08-07 10:23:15,421 INFO [backend.app.services.virtual_printer.mqtt_server] [-] Simple MQTT server listening on port 8883
    bambuddy  | 2026-08-07 10:23:15,421 INFO [backend.app.services.virtual_printer.tcp_proxy] [-] Camera-6000 TCP proxy listening on port 6000
    bambuddy  | 2026-08-07 10:23:15,421 INFO [backend.app.services.virtual_printer.bind_server] [-] Bind server listening on 10.0.0.12:3000 (plain)
    bambuddy  | 2026-08-07 10:23:15,421 INFO [backend.app.services.virtual_printer.mqtt_server] [-] Starting periodic status push task
    bambuddy  | 2026-08-07 10:23:15,421 INFO [backend.app.services.virtual_printer.bind_server] [-] Bind server listening on 10.0.0.12:3002 (TLS)
    bambuddy  | 2026-08-07 10:23:15,421 INFO [backend.app.services.virtual_printer.manager] [-] [VP Test] Server-mode services started on 10.0.0.12
    bambuddy  | 2026-08-07 10:23:15,422 INFO [backend.app.services.virtual_printer.manager] [-] Started server-mode VP: Test on 10.0.0.12
    bambuddy  | 2026-08-07 10:23:15,422 INFO [root] [-] Virtual printer manager synced from database
      Please open an issue on Github.
