  4. Connection between Bambuddy and Spoolman
13 Posts 3 Posters 1.2k Views 3 Watching
  • MartinNYHCM Offline
    MartinNYHCM Offline
    what version you are running?
    • M Offline
      M Offline
      Moskito
      wrote on last edited by Moskito
      #5
      v0.2.3.2 - updatet this morning
        MartinNYHCM Offline
        Check your logs for errors.
        • M Offline
          M Offline
          Moskito
          On startup with postgresql this messages came up, but i don't think tis is relevant for the problem:
          bambuddy-db  | 2026-04-24 14:02:18.762 UTC [37] ERROR:  syntax error at or near "AUTOINCREMENT" at character 112
          bambuddy-db  | 2026-04-24 14:02:18.762 UTC [37] STATEMENT:
          bambuddy-db  |                  CREATE TABLE IF NOT EXISTS active_print_spoolman (
          bambuddy-db  |                      id INTEGER PRIMARY KEY AUTOINCREMENT,
          bambuddy-db  |                      printer_id INTEGER NOT NULL REFERENCES printers(id) ON DELETE CASCADE,
          bambuddy-db  |                      archive_id INTEGER NOT NULL REFERENCES print_archives(id) ON DELETE CASCADE,
          bambuddy-db  |                      filament_usage TEXT NOT NULL,
          bambuddy-db  |                      ams_trays TEXT NOT NULL,
          bambuddy-db  |                      slot_to_tray TEXT,
          bambuddy-db  |                      layer_usage TEXT,
          bambuddy-db  |                      filament_properties TEXT,
          bambuddy-db  |                      UNIQUE(printer_id, archive_id)
          bambuddy-db  |                  )
          bambuddy-db  | 2026-04-24 14:02:18.803 UTC [37] ERROR:  syntax error at or near "AUTOINCREMENT" at character 110
          bambuddy-db  | 2026-04-24 14:02:18.803 UTC [37] STATEMENT:
          bambuddy-db  |                  CREATE TABLE IF NOT EXISTS spool_usage_history (
          bambuddy-db  |                      spool_id INTEGER NOT NULL REFERENCES spool(id) ON DELETE CASCADE,
          bambuddy-db  |                      printer_id INTEGER REFERENCES printers(id) ON DELETE SET NULL,
          bambuddy-db  |                      print_name VARCHAR(500),
          bambuddy-db  |                      weight_used REAL NOT NULL DEFAULT 0,
          bambuddy-db  |                      percent_used INTEGER NOT NULL DEFAULT 0,
          bambuddy-db  |                      status VARCHAR(20) NOT NULL DEFAULT 'completed',
          bambuddy-db  |                      created_at DATETIME NOT NULL DEFAULT CURRENT_TIMESTAMP
          bambuddy-db  |                  )
          This warnings came up every 15 minutes or so:
          bambuddy     | 2026-04-24 16:04:29,965 WARNING [backend.app.api.routes.cloud] Failed to get cloud preset S7043929 (API ID: S7043929): Failed to get setting detail: 400
          bambuddy     | 2026-04-24 16:04:30,190 WARNING [backend.app.api.routes.cloud] Failed to get cloud preset S7043928 (API ID: S7043928): Failed to get setting detail: 400
          bambuddy     | 2026-04-24 16:04:30,396 INFO [backend.app.services.firmware_check] Got Bambu Lab build ID: skeiEP5Hs-sR8shWSQHlC
          bambuddy     | 2026-04-24 16:04:30,444 INFO [backend.app.services.firmware_check] Got Bambu Lab build ID: skeiEP5Hs-sR8shWSQHlC
          bambuddy     | 2026-04-24 16:04:30,446 WARNING [backend.app.api.routes.cloud] Failed to get cloud preset S8492713 (API ID: S8492713): Failed to get setting detail: 400
          bambuddy     | 2026-04-24 16:04:30,621 WARNING [backend.app.api.routes.cloud] Failed to get cloud preset GFU99 (API ID: GFSU99): Failed to get setting detail: 400
          bambuddy     | 2026-04-24 16:04:30,663 WARNING [backend.app.api.routes.cloud] Failed to get cloud preset S7043929 (API ID: S7043929): Failed to get setting detail: 400
          In the meantime i lost all of my archived because of the back and forward sqlite and postgresql...
          If nobody has a clue, I would start from scratch.
            MartinNYHCM Offline
            You database table was not properly updated after an upgrade.
            • M Offline
              M Offline
              Moskito
              Okay, than i will wipe it completely and start from scratch. 😞
              Hopefully is it the last time to do this...
              Fingers crossed...
              Thanks anyway!
              • M Offline
                M Offline
                Moskito
                Okay, wiped everything with "docker system prune -a" and startet from scratch.
                Doesn't work.
                Get DB error messages on startup:
                database.log.txt
                Table spool only show the BL spool.
                Table spool_assignment still empty.
                  MartinNYHCM Offline
                  Open an issue please. Need more details.
                  Link Preview Image
                  System Info - Bambuddy Documentation
                  View database statistics and system resources
                  favicon
                  Bambuddy Documentation (wiki.bambuddy.cool)
                  • F Offline
                    F Offline
                    FO22ZZ
                    Following. I think I am having a similar issue and just did a fresh install to no avail.
                    • M Offline
                      M Offline
                      Moskito
                      Bug: https://github.com/maziggy/bambuddy/issues/1119
