  3. Won't install
Won't install
Scheduled Pinned Locked Moved General Discussion
5 Posts 2 Posters 672 Views 2 Watching
  • J
    J
    jsimmonstx
    OS: Linux Mint 22.3, updated to latest packages (installed 10 minutes ago).
    Intel NUC:
    • CPU i3-6100
    • 8gb RAM
    • 210GB of free hard drive space
    I'm trying to do a native install with this command:
    curl -fsSL https://raw.githubusercontent.com/maziggy/bambuddy/main/install/install.sh -o install.sh && chmod +x install.sh && ./install.sh
    I get this error:
    curl: (23) Failure writing output to destination
    So I tried the same command with sudo, and got this error:
    chmod: changing permissions of 'install.sh': Operation not permitted
    I'm at the very edge of my linux trouble-shooting abilities.
    • J
      J
      jsimmonstx
      I didn't see Mint in the list of compatible OS's, but since it's based on Ubuntu, I assumed it would be okay. Is that an incorrect assumption?
      BTW, the time limit on editing a post is arbitarrary and absurd. I don't see the point at all...
      • A
        A
        ash_t
        That's a bit weird, can you run the commands one after the other?
        First curl -fsSL https://raw.githubusercontent.com/maziggy/bambuddy/main/install/install.sh -o install.sh
        Then chmod +x install.sh
        Then sudo ./install.sh
        Report back here on the errors you face and I'll try to help you troubleshoot.
        • J
          J
          jsimmonstx
          i came back to say i fingered it out. i had to sudo chmod, and then i was able to run install.sh
          • J
            J
            jsimmonstx
            And i'm up and running!
