  2. General Discussion
  3. Help
  4. Getting Started: How to Install Bambuddy (Docker)
Scheduled Pinned Locked Moved Help
1 Posts 1 Posters 514 Views 1 Watching
  • adminA
    adminA
    admin
    This guide walks you through installing Bambuddy using Docker — the recommended method.
    Prerequisites
    • Docker and Docker Compose installed on your system
    • A Bambu Lab printer with Developer Mode enabled
    • "Store sent files on external storage" enabled in Bambu Studio or OrcaSlicer
    • Printer and server on the same local network
    Installation
    Option A: Pre-built Image (Fastest)
    mkdir bambuddy && cd bambuddy
    curl -O https://raw.githubusercontent.com/maziggy/bambuddy/main/docker-compose.yml
    docker compose up -d
    That's it! Open http://your-server-ip:5000 in your browser.
    Option B: Build from Source
    git clone https://github.com/maziggy/bambuddy.git
    cd bambuddy
    docker compose up -d --build
    Multi-Architecture Support
    Bambuddy runs on both AMD64 and ARM64 (Raspberry Pi 4/5). Docker will automatically pull the correct image.
    macOS / Windows (Docker Desktop)
    Docker Desktop doesn't support host networking. You'll need to enter your printer's IP address manually in Bambuddy settings instead of relying on auto-discovery.
    Updating
    docker compose pull
    Daily Beta Builds
    Want to try the latest features? Use the daily build tag:
    image: ghcr.io/maziggy/bambuddy:daily
    Note: Daily builds are never tagged as latest — you need to explicitly opt in.
    First Steps After Install
    1. Open Bambuddy in your browser
    2. Go to Settings > Printers and add your printer's IP and access code
    3. Your printer should appear on the dashboard within seconds
    4. Start a print from your slicer — it will be automatically archived!
    Having trouble? Check the Documentation or ask in the Help category.
