  4. Windows native install problems
12 Posts 2 Posters 48 Views 2 Watching
  • MartinNYHCM Offline
    MartinNYHCM Offline
    wrote last edited by
    #2
    That sounds clearly like you didn't follow the install instructions.
    Check https://wiki.bambuddy.cool/getting-started/
    • I Offline
      I Offline
      Ingenuity 0
      #3
      Look, I get it. I'm a manufacturer that also produces a product and I sell worldwide so I know what it is like dealing with millions of customers. Some of them can understand your instructions and some take forever to get it. LOL, I guess the shoes been reversed and now I'm the customer that I hate dealing with as well. I'm just not extremely versed in this deep of programming and coding to understand even though I've read it 10 times. It seems like most of the instructions are explaining how it works during the install giving you 100x more information than one is needed to actually just do the install if you do not understand the lingo.
      Running the native install with powershell, (had no idea what powershell even was or ever heard of it) it basically just took off and did it all itself only pausing a couple times for you to answer a question i had no idea how to answer so just guessed like lan access y/n, windows service y/n.
      Like I said, It all is somewhat working but a couple things and I do not know where i went wrong.
        MartinNYHCM Offline
        #4
        The problem is Windows. We had multiple contributors working on it and we couldn't find a way to get one Windows install script that does work for more then 5 computers. And since I don't have any Windows knowledge at all I don't know what to do.
        Thus, we are recommending a Docker install for Windows.
        • I Offline
          I Offline
          Ingenuity 0
          #5
          Ok, I can understand that. Is there a special procedure to completely uninstall what it put on my computer to start over with the docker install, which by the way again I have no idea what docker even is. LOL
          What country are you in? If you do not mind me asking
            MartinNYHCM Offline
            wrote last edited by MartinNYHC
            #6
            Just built a first version of a native Windows installer. Can you try it?
            https://github.com/maziggy/bambuddy/releases/latest/download/bambuddy-windows-x64-setup.exe
            or
            https://github.com/maziggy/bambuddy/releases/download/v0.2.5b1-daily.20260610/bambuddy-0.2.5b1-daily.20260610-windows-x64-setup.exe
            • I Offline
              I Offline
              Ingenuity 0
              #7
              How do I erase the previous install for a clean slate ?
                MartinNYHCM Offline
                #8
                No need for it.
                • I Offline
                  I Offline
                  Ingenuity 0
                  #9
                  Thank you I will try your link
                  • I Offline
                    I Offline
                    Ingenuity 0
                    #10
                    Link downloaded ok but once application was open it just acts really slow. I never could even get it to open the settings screen.
                    • I Offline
                      I Offline
                      Ingenuity 0
                      #11
                      It says no printers found on the network when you try to discover printers on the network and says failed to fetch as well
                      • I Offline
                        I Offline
                        Ingenuity 0
                        #12
                        Ok, some good news. I uninstalled all versions and reinstalled from your link again and most everything seems to be working. I connected a printer. I even was able to make the virtual printer ,but the issue now is the slicer sees the virtual printer but fails to connect to it every time i try.
