  4. Windows native install problems
15 Posts 2 Posters 1.3k Views 2 Watching
    The problem is Windows. We had multiple contributors working on it and we couldn't find a way to get one Windows install script that does work for more then 5 computers. And since I don't have any Windows knowledge at all I don't know what to do.
    Thus, we are recommending a Docker install for Windows.
    • I
      I
      Ingenuity 0
      Ok, I can understand that. Is there a special procedure to completely uninstall what it put on my computer to start over with the docker install, which by the way again I have no idea what docker even is. LOL
      What country are you in? If you do not mind me asking
        wrote on last edited by MartinNYHC
        #6
        Just built a first version of a native Windows installer. Can you try it?
        https://github.com/maziggy/bambuddy/releases/latest/download/bambuddy-windows-x64-setup.exe
        or
        https://github.com/maziggy/bambuddy/releases/download/v0.2.5b1-daily.20260610/bambuddy-0.2.5b1-daily.20260610-windows-x64-setup.exe
        • I
          I
          Ingenuity 0
          How do I erase the previous install for a clean slate ?
            No need for it.
            • I
              I
              Ingenuity 0
              Thank you I will try your link
              • I
                I
                Ingenuity 0
                Ok, some good news. I installed your link but it did not work properly after opening application so I completely did uninstall of both versions and then reinstalled your link and all seems to be working better now as expected except one thing so far. I was able to add a printer and even build the virtual printer this time no problem but the slicer refuses to connect to it either from Studio or Orca.
                  You dodn't follow th einstall instructions - the certificate is not imported.
                  • I
                    I
                    Ingenuity 0
                    yes, I copied and pasted it at the end of the list
                      Please open an issue on Github. Nedd to check more detailed.
                      • I
                        I
                        Ingenuity 0
                        How do I do that? I'm not real familiar wit github. When I search Bambuddy in github it says there are 1400 issues? That is a lot of issues! If I click create new issue at the top the depository defaults to bambulab/bambustudio?
                          Link Preview Image
                          Issues · maziggy/bambuddy
                          Your Bambu Lab. No Cloud. Your Rules. Self-hosted command center for Bambu Lab — from one A1 to an entire print farm. - Issues · maziggy/bambuddy
                          favicon
                          GitHub (github.com)
                          New issue
