  4. Windows native install problems
15 Posts 2 Posters 1.3k Views 2 Watching
    wrote on last edited by MartinNYHC
    #6
    Just built a first version of a native Windows installer. Can you try it?
    https://github.com/maziggy/bambuddy/releases/latest/download/bambuddy-windows-x64-setup.exe
    or
    https://github.com/maziggy/bambuddy/releases/download/v0.2.5b1-daily.20260610/bambuddy-0.2.5b1-daily.20260610-windows-x64-setup.exe
    • I
      I
      Ingenuity 0
      How do I erase the previous install for a clean slate ?
        No need for it.
        • I
          I
          Ingenuity 0
          Thank you I will try your link
          • I
            I
            Ingenuity 0
            Ok, some good news. I installed your link but it did not work properly after opening application so I completely did uninstall of both versions and then reinstalled your link and all seems to be working better now as expected except one thing so far. I was able to add a printer and even build the virtual printer this time no problem but the slicer refuses to connect to it either from Studio or Orca.
              You dodn't follow th einstall instructions - the certificate is not imported.
              • I
                I
                Ingenuity 0
                yes, I copied and pasted it at the end of the list
                  Please open an issue on Github. Nedd to check more detailed.
                  • I
                    I
                    Ingenuity 0
                    How do I do that? I'm not real familiar wit github. When I search Bambuddy in github it says there are 1400 issues? That is a lot of issues! If I click create new issue at the top the depository defaults to bambulab/bambustudio?
                      Link Preview Image
                      Issues · maziggy/bambuddy
                      Your Bambu Lab. No Cloud. Your Rules. Self-hosted command center for Bambu Lab — from one A1 to an entire print farm. - Issues · maziggy/bambuddy
                      favicon
                      GitHub (github.com)
                      New issue
