  4. Troubleshooting: Common Issues and Solutions
1 Posts 1 Posters 396 Views 1 Watching
  • adminA
    adminA
    admin
    A collection of frequently reported issues and their solutions.
    Printer Shows as Offline
    Cause: Network connectivity or Developer Mode not enabled.
    Fix:
    1. Verify Developer Mode is enabled on the printer
    2. Confirm the printer and Bambuddy are on the same network/VLAN
    3. Check the IP address in Settings > Printers
    4. Restart the printer if it was recently updated
    Camera Not Showing Preview
    Cause: Camera stream not accessible or blocked.
    Fix:
    1. Make sure the camera is enabled in your printer's settings
    2. Check that port 6000 (RTSP) is not blocked by a firewall
    3. For X1C/P1S: camera works over LAN only with Developer Mode
    4. Try refreshing the browser or clearing cache
    Print Won't Start from Queue/Archive
    Cause: Filament mismatch, printer busy, or file transfer issue.
    Fix:
    1. Check that the printer has the required filaments loaded
    2. Make sure the printer isn't already printing or in error state
    3. Check the queue status — it might be in "Queue Only" mode
    4. Verify the 3MF file isn't corrupted (try downloading and opening in slicer)
    Large File Upload Fails
    Cause: Timeout or proxy configuration.
    Fix:
    1. If using a reverse proxy, increase client_max_body_size and timeouts
    2. For direct access, check available disk space
    3. Try a wired connection instead of WiFi
    AMS Mapping Shows Wrong Colors
    Cause: AMS slot configuration out of sync.
    Fix:
    1. Go to the Printers page and click on the AMS slots to refresh
    2. Try the RFID re-read button for affected slots
    3. Ensure spools are properly assigned in the Spool Inventory
    Docker on Windows: Network Issues
    Cause: Docker Desktop doesn't support host networking.
    Fix:
    1. Enter your printer's IP address manually in Bambuddy settings
    2. Don't rely on auto-discovery (SSDP) — it won't work through Docker Desktop's NAT
    Still stuck? Create a new topic in the Help category with:
    • Your Bambuddy version
    • Printer model
    • A Support Package
