  4. server-side slicing setup
18 Posts 2 Posters 464 Views 2 Watching
  • MartinNYHCM Offline
    MartinNYHCM Offline
    wrote last edited by MartinNYHC
    #8
    To me it looks like you have a wrong expectation what internal slicing does. Did you read the docs?
    L 1 Reply Last reply
      MartinNYHCM Offline
      #9
      BTW: it is NOT mandatory for you to run Bambuddy via Docker - only the slicer sidecar needs Docker.
      • MartinNYHCM MartinNYHC
        L Offline
        L Offline
        luke.jaeger
        #10
        @MartinNYHC I think I understand how it's supposed to work! The docs don't indicate too much about how the app is supposed to look to the user, so I'm having a hard time figuring out what's wrong. Comparing it to the online demo, I notice a couple of issues:
        1. I can upload an .stl file to my self-hosted instance and I can slice it using the Slice command in the three-dot menu. The 3mf file appears like it should. BUT if I try to 3D preview the .3mf file, I get a frowny icon and "[FQDN] refused to connect."
          I can 3D preview an .stl file, but not the .3mf.
        2. options for auto-rotate and auto-orient do not appear in my slicing dialog.
          MartinNYHCM Offline
          #11
          For 1) please open an issue on Github
          1. is only available in daily beta build and with the next release.
            MartinNYHCM Offline
            #12
            BTW: [FQDN]? Are you running a reverse proxy? Looks like a service is not running or connecting to the wrong host.
            • L Offline
              L Offline
              luke.jaeger
              #13
              yes we have a reverse proxy.
              so for now should we slice everything in desktop Bambu Studio and upload .gcode.3mf files to bambuddy?
                MartinNYHCM Offline
                #14
                I cannot answer your question because I don't know your desired workflow.
                • L Offline
                  L Offline
                  luke.jaeger
                  #15
                  we're an academic makerspace and we want the workflow to be as easy as possible for students, while still allowing us to track usage.
                  Seems to me the workflow would look like this:
                  1. students set up their .stl files in Bambu Studio desktop app, get all the orientation & supports right, etc
                  2. slice & export to .gcode.3mf
                  3. upload to Bambuddy
                  I'd love it if they could do step 1 & 2 inside Bambuddy but sounds like that's not possible.
                  thanjks for all your help btw!
                  • L Offline
                    L Offline
                    luke.jaeger
                    #16
                    trying to create an issue on Github and I cannot find the System Info page anywhere! Shouldn't it be visible in Settings somewhere?
                      MartinNYHCM Offline
                      #17
                      • L Offline
                        L Offline
                        luke.jaeger
                        #18
                        AHA thanks
