  4. Problem Installing on Linux Machine
7 Posts 2 Posters 512 Views 2 Watching
  • DofD10D Offline
    DofD10D Offline
    DofD10
    Hi There
    So i wanted to install Bambuddy on my machine and used the command provided.
    Yet i get the error that the Docker Deamon is not running, yet i checked and it should run as the dockerd command shows.
    alt text
    Any ideas?!
    Thanks for the help!
    • MartinNYHCM Offline
      MartinNYHCM Offline
      Mhhh...never saw that before. Restart Docker and check your logs for errors.
      • DofD10D Offline
        DofD10D Offline
        DofD10
        Still showing error after restarting
        alt text
          MartinNYHCM Offline
          You are checking the wrong service.
          systemctl status docker.s
          docker.service docker.socket
          doocker.service is the right one.
          • DofD10D Offline
            DofD10D Offline
            DofD10
            wrote on last edited by DofD10
            #5
            Then I dont understand, are there different versions of docker?
            I used the install guide at https://docs.docker.com/engine/install/ubuntu/ and checked that it is running.
            Do i miss something here? If i do it the manual way (pre built image) it just works...
            Sorry for this basic question as this is the first time i am running into problems with docker.
              MartinNYHCM Offline
              Just do
              sudo systemctl enable --now docker.service && sudo systemctl status docker.service
              • DofD10D Offline
                DofD10D Offline
                DofD10
                Still doesnt work.
                But I got it working via "manual" mode. Here it just worked.
                Pulled the image and fired up the container. 🙃🤪
                Still thanks for your help and this great programm! 🤘😁
